Home > Technical > l494 rrs 2013/14 chassis control module
maci234
would anyone know what the letter are on this module i,m having issue with the connection going to the WH ,whats that connection running
Post #648228 Mon Jun 02 2025 10:23pm
Disco_Mikey
4 Corner Air Suspension + Continuous Variable Damping + Terrain Response
Post #648231 Tue Jun 03 2025 6:01am
maci234
the connection i,m having a problem with is the one with WH above it does anyone know what that controls
Post #648232 Tue Jun 03 2025 9:53am
2 RRS
United Kingdom 2013 Range Rover Sport SDV6 Autobiography Bourneville
Here you go
Pop the WH (white connector) off and check pin numbers and then refer to the diagram.
https://www.rrsport.co.uk/gallery/albums/u...ension.pdf
Looking at the diagram I would go for connector D, so anything starting C4CL14D- on the diagram.
When you say you have a problem with the white connector, what brings you to this conclusion?
Post #648233 Tue Jun 03 2025 9:58am
maci234
the fuse controlling that unit chassis , only getting reading of 5.4 v removed white plug from that went up 11 volts so i,m not sure yet whats causing this , car is non start at moment lots of faults on dash, no lights on gear lever or terrain response ,
Post #648234 Tue Jun 03 2025 11:13am
2 RRS
It's going to be a case of unplugging items that go to the WH connector one by one to see if the voltage recovers, sounds like something has a short and is pulling it down, or could be a bad earth.
Post #648236 Tue Jun 03 2025 1:22pm
maci234
yes it may be something simple its just finding it
Post #648237 Tue Jun 03 2025 1:28pm
