![]() | Home > Technical > l494 rrs 2013/14 chassis control module |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4521 ![]() ![]() ![]() |
4 Corner Air Suspension + Continuous Variable Damping + Terrain Response |
maci234 Member Since: 12 Oct 2014 Location: scotland Posts: 197 ![]() ![]() ![]() |
the connection i,m having a problem with is the one with WH above it does anyone know what that controls |
2 RRS Member Since: 04 Sep 2016 Location: Shropshire Posts: 225 ![]() ![]() ![]() |
Here you go
the fuse controlling that unit chassis , only getting reading of 5.4 v removed white plug from that went up 11 volts so i,m not sure yet whats causing this , car is non start at moment lots of faults on dash, no lights on gear lever or terrain response , |
It's going to be a case of unplugging items that go to the WH connector one by one to see if the voltage recovers, sounds like something has a short and is pulling it down, or could be a bad earth. |
yes it may be something simple its just finding it |
