![]() | Home > Maintenance & Modifications > Transmission Service ZF 8HP |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4531 ![]() ![]() ![]() |
Fluid level low, most likely |
haydarbolat Member Since: 05 Aug 2024 Location: London Posts: 8 ![]() ![]() |
Thank you for your response. You were right I forgot to refill with the engine running. I re drained the oil 2L came out and with engine running after second fill took a total of 3.5L. The gears are now smooth specially from start stop to gear one which was violent last couple of days. Gear 2-3 seems still jerky but I guess that’s the adaptation period from the reset.
