![]() | Home > My Range Rover Sport > Range Rover Sport L320 3.0 sdv6 No compression |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5150 ![]() ![]() ![]() |
I think initially I would check that the timing belt has not snapped, and the pistons have clouted the valves etc. although you do say the camshaft turns or do you mean the crankshaft?
Isegrimm Member Since: 26 May 2025 Location: 8132 Pernegg an der Mur Posts: 3 ![]() ![]() |
The timing belt is OK. Engine was turned by hand by the mechanic. Crankshaft is not blocked. When starting, you can see through the oil inlet cover that the camshaft is rotating. On the other hand you can hear the camshaft turning. |
So does the engine actually start or just spin over? Your post heading says no compression, have you actually done a compression test.
The engine spins. The mechanic said we can hear that there is no compression. A compression test was not done. No workshop wanted to do it. Reason too complex and therefore too expensive. I couldn't carry out a compression test myself because I didn't have the data. How much pressure should be. |
