Home > Faults & Fixes > 2013 L320 Suspension air compressor question.
Cpt Jack Sparrow
Wales 2013 Range Rover Sport SDV6 HSE Fuji White
Good afternoon all
after many weekends of procrastination I finally decided to tack my suspension error, which is basically the air tank filling too slowly.
Checked system and have no leaks so I presumed it was the compressor on its way out, So today I dropped it out.
My question is can any one identify this compressor, its clearly been replaced before as the car is a 2013 and the compressor was checked by Billy in 2018 Very Happy
Clearly not genuine but has lasted up to 7 years, suggestions for replacement greatly received.
Cheers CJS Thumbs Up Thumbs Up
Post #648034 Sun May 18 2025 3:57pm
Cpt Jack Sparrow
OK so my googling find this to be an Arnott P-2815 Air suspension compressor. £565.00
So must be fairly decent, any one with experience of these can they be serviced to tested for faults?
Thanks
CJS
Post #648035 Sun May 18 2025 4:45pm
Cpt Jack Sparrow
Ok so being the person I am... and a life moto of
If it ain't broke fix it 'til it is........
I started to strip this thing apart, starting with the obvious the drier chamber... well I think I have found the problem, the first filter was damp and running my pick over it actually squeezed to liquid like a sponge. under that the desiccant is soaked.. litterally sticking together with moisture.. this would severely restrict the flow through the chamber and then cause the tank to fill slowly.
I have ordered new filters and desiccant to see if this cure the issue.. ill let you know.
CJS
Post #648038 Sun May 18 2025 5:38pm
Cpt Jack Sparrow
I can report I have resolved the error on the dash,
as no one is interested in this post I won't waste time posting the results and how I did it... and just close the thread.
Thanks for the help all who posted Thumbs Up Thumbs Up
Post #648139 Sat May 24 2025 8:16pm
SpiderPig
Good result.
If you can, it'll probably help those who follow if you could update the thread.
I saw someone on Facebook the other day with a similar problem. 2021 P400e Autobiography
Post #648176 Wed May 28 2025 3:24pm
