![]() | Home > Faults & Fixes > Dash Cluster Keeps Failing |
Meshan Member Since: 19 Oct 2024 Location: Northampton Posts: 97 ![]() ![]() ![]() |
So my dash cluster keep failing - powering down, no lights, no speedo, no indicators.
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5153 ![]() ![]() ![]() |
If I remember right if the replacement dash cluster you use has a higher milage recorded than the original it will record the higher milage in the memory and will not revert back to the lower milage when the original is refitted as it is recorded in the cluster memory and I think it's the bcm ecu. module as well.
Cheers, Col,
