![]() | Home > Faults & Fixes > L320 3.0 tdv6 suspension drops |
dt4 Member Since: 07 Sep 2024 Location: East Yorks Posts: 4 ![]() ![]() ![]() |
No thoughts / advice? |
Meshan Member Since: 19 Oct 2024 Location: Northampton Posts: 89 ![]() ![]() ![]() |
Any codes?
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9115 ![]() ![]() ![]() |
Will it rise up to normal height by selecting the raise button on the console?
Thanks for the advice It doesnt always drop and its not the same side or same corner each time |
Thanks for the advice It returns to normal height some times by itself and sometimes I have to select access height then normal ride height Its a yellow triangle on the dash Ill have to find a place locally that can read the codes |
