Home > Faults & Fixes > L320 3.0 tdv6 suspension drops
dt4
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Buckingham Blue
Im not clued up on air / hydraulic suspension at all.
ve had the car around 9 months without any problems but yesterday a suspension fault error message came on the display.
I googled possible causes and a quick fix suggested turning the steering wheel to full lock left then right to clear the fault, that didnt work.
This morning I went to the car and when I opened the passenger door to get something out the suspension "sighed" and dropped down so that the wheels are sat into the wheel arches.
I dont have any fault reading gizmos so just looking for thoughts / advice
thanks
David
Post #647911 Fri May 09 2025 9:06am
dt4
No thoughts / advice?
Post #648037 Sun May 18 2025 5:34pm
Meshan
Any codes?
Could be compressor, reservoir, valve blocks or suspension bags.
Dropping overnight could be the valve block, if you are lucky, or suspension bags if you are not. Dropping immediately could be the bags. Inflate, spray with soapy water and check for leaks.
Also spray the reservoir and check that. They rust L320 Range Rover Sport 2008
3.6 TDV8
Remap
EGR Blank
Post #648040 Sun May 18 2025 8:19pm
Will it rise up to normal height by selecting the raise button on the console?
Is there a yellow or red error light on the dash?
There are a number of possible causes and you really do need to get the fault codes read as part of the process. 2012 SDV6 - it's missing a couple of cylinders
Post #648044 Mon May 19 2025 11:01am
dt4
Meshan wrote:
Any codes?
Thanks for the advice
It doesnt always drop and its not the same side or same corner each time
Post #648050 Mon May 19 2025 6:35pm
dt4
It returns to normal height some times by itself and sometimes I have to select access height then normal ride height
Its a yellow triangle on the dash
Ill have to find a place locally that can read the codes
Post #648051 Mon May 19 2025 6:39pm
