![]() | Home > Wheels & Tyres > Wheel alignment |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5150 ![]() ![]() ![]() |
Did the place you used initially not give you a print out of the readings? Could try your postcode here to see if anyone with the Hunter Alignment equipment comes up near you.
daxmatt Member Since: 16 Aug 2014 Location: kent Posts: 221 ![]() |
Yep, gave me a printout of before and after,
jorosa Member Since: 01 Dec 2012 Location: Lincolnshire Posts: 30 ![]() ![]() |
I previously had an 06 supercharged and took it to places that have the Hunter 4 wheel alignment, but unless they can plug the car in and put it in "Tight Tolerance mode" you are wasting your time & money as i did. The only garage that got the alignment bang on was the Main Dealer, completely transformed the drive and steering 2024 Range Rover Sport D300 Dynamic SE in Varesine Blue
Meshan Member Since: 19 Oct 2024 Location: Northampton Posts: 93 ![]() ![]() ![]() |
How much was an alignment at the main dealer? L320 Range Rover Sport 2008
How long did they have the car for ? |
You do not need diag. equipment etc. to put the L494 in tight tolerance mode, if I understand correctly as you can do it yourself with a manual procedure.
This is what i had done a few weeks back, I noticed it just said Range Rover Sport, I take it the SVR settings are the same ?
Went to another place:-
