Home > Wheels & Tyres > Wheel alignment
daxmatt
Wheel alignment
Anyone know of any good 4 wheel alignment places in the kent area.
My SVR seems to follow the ruts, and very very slightly pulls to the left,or seems too. Has 295x40x22 tyres.
My old 06 supercharged seems to drive a lot nicer steering wise.has 22s on aswell
Have taken to an alignment place in Braintree Essex, they said was pretty much spot on and didn't really need adjusting, i asked them to anyway.
I had a look at home afterwards, could not see any sign of any nuts/bolts being touched.
I returned car to dealer ,they drove it, they agreed with me, just said its down to tyres/wheels Big Cry
Post #647885 Tue May 06 2025 8:48pm
Did the place you used initially not give you a print out of the readings? Could try your postcode here to see if anyone with the Hunter Alignment equipment comes up near you.
https://alignmycar.co.uk/
Post #647887 Tue May 06 2025 9:12pm
daxmatt
Yep, gave me a printout of before and after,
Thanks, I'll give them a call Thumbs Up
Post #647889 Tue May 06 2025 9:30pm
jorosa
I previously had an 06 supercharged and took it to places that have the Hunter 4 wheel alignment, but unless they can plug the car in and put it in "Tight Tolerance mode" you are wasting your time & money as i did. The only garage that got the alignment bang on was the Main Dealer, completely transformed the drive and steering 2024 Range Rover Sport D300 Dynamic SE in Varesine Blue
2019 Mercedes E Class Estate E350d (Gone)
2017 Mercedes C43 Cabriolet
2013 Jaguar XF Estate 3.0d (Gone)
2016 Mercedes CLA Estate 220d (Gone)
2006 Range Rover Sport 4.2 Supercharged (Gone)
Post #647894 Wed May 07 2025 1:25pm
Meshan
How much was an alignment at the main dealer? L320 Range Rover Sport 2008
3.6 TDV8
Remap
EGR Blank
Post #647896 Wed May 07 2025 5:16pm
daxmatt
How long did they have the car for ?
Post #647898 Wed May 07 2025 8:26pm
You do not need diag. equipment etc. to put the L494 in tight tolerance mode, if I understand correctly as you can do it yourself with a manual procedure.
Activation:
1. Gearbox in Park
2. Start the engine
3. Suspension in normal height
4. Open the driver's door
5. Press the brake pedal 3 times
6. Close the driver's door within 10 seconds of the first brake pedal press
If successful, the instrument cluster will emit two soft chimes after the driver's door is closed, to indicate the air suspension system is in TTM.
Deactivation:
Turn the engine off or drive the vehicle over 5 mph.
Post #647899 Wed May 07 2025 10:52pm
daxmatt
This is what i had done a few weeks back, I noticed it just said Range Rover Sport, I take it the SVR settings are the same ?
Post #647998 Thu May 15 2025 6:11pm
daxmatt
Went to another place:-
Tollgate Tyres , Leaves Green, Biggin Hill.
Knew about tight tolerance mode. £80
All sorted Very Happy
Post #648137 Sat May 24 2025 6:52pm
