Home > Technical > Startung trouble: key won't turn. When it does, it cranks wi
RossHornblower
Hey guys. I'm new to this. I have a 2005 RR Sport Supercharged. 110 K miles. Had a brand new V8 engine installed a couple of years back. New starter-motor installed too, separately (can't remember if before or after) by a mobile specialist who came to the house. Been having trouble getting the key even to turn in the ignition. Full battery helps but cranks energetically without firing. Used to occasionally fire and run for a few seconds before cutting out. Lots of fuel in the tank. Anyone got any ideas?? Oh yeah, yesterday I plugged into the diagnostics socket a very basic code-detecting device. The two codes I'm getting are P0657 and P0700. Any ideas, guys? It just occurred to me to turn the key to ON and listen for an electric fuel pump clicking sound, right? To eliminate that possibility....Anyway, cheers all!
Post #644181 Wed Sep 11 2024 4:36am
JonnyCJ
Google the two codes and start from there. It’ll give you some areas to read around and apply to your car.
Let us know how you get on.
Post #644187 Wed Sep 11 2024 10:43am
P0657 is "Actuator Supply Voltage A circuit/open" i.e. high resistance. Manual suggests running through the guided diagnostic routine. So you need someone who has a suitable proper diagnostic equipment.
P0700 is a transmission control system fault.
Best advice is take it to a specialist LR independent (not a main dealer) who can look in to it properly. Otherwise you're chasing smoke at this stage. 2012 SDV6 - it's missing a couple of cylinders
Post #644191 Wed Sep 11 2024 4:12pm
All those codes do seem to be related to the transmission control module.
Post #644193 Wed Sep 11 2024 5:05pm
RossHornblower
To all three of you guys who replied, and therefore helped in answering my question: thank you!
Post #644504 Wed Oct 02 2024 4:52pm
