![]() | Home > Technical > Startung trouble: key won't turn. When it does, it cranks wi |
JonnyCJ Member Since: 25 Apr 2011 Location: Wirral Posts: 433 ![]() ![]() |
Google the two codes and start from there. It’ll give you some areas to read around and apply to your car.
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9138 ![]() ![]() ![]() |
P0657 is "Actuator Supply Voltage A circuit/open" i.e. high resistance. Manual suggests running through the guided diagnostic routine. So you need someone who has a suitable proper diagnostic equipment.
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5134 ![]() ![]() ![]() |
All those codes do seem to be related to the transmission control module.
RossHornblower Member Since: 11 Sep 2024 Location: Slough Posts: 2 ![]() ![]() ![]() |
To all three of you guys who replied, and therefore helped in answering my question: thank you! |
