![]() | Home > Maintenance & Modifications > RRS 2011 ACE pipe leak HELP |
jig Member Since: 14 Jan 2018 Location: London Posts: 47 ![]() ![]() |
Also is there anything I can paint onto the pipes to strengthen or prevent further rusting? Thanks |
Bump |
Pistnbroke Member Since: 22 Sep 2020 Location: rugby Posts: 471 ![]() ![]() ![]() |
If its leaking you will have to replace it . A hydraulic pipe is only about £30.
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9151 ![]() ![]() ![]() |
There are a number of products that deal with rust. They generally convert the rust from iron oxide to a phosphate that doesn't corrode further. You then need to coat/paint the metal to stop further attacks. Only way to make the pipes stronger is to replace them. And as said, if it's leaking, it has to be replaced. 2012 SDV6 - it's missing a couple of cylinders
Thanks Piston I was thinking of cutting and fitting hydraulic pipe made up with compression fittings then painting all the rusted areas with the Marine Epoxy to prevent further weakness. |
Thanks RRSTDV8. I am hoping to cut section and replace with hydraulic pipe with compression fitting. Any specific product you recommend for the rusted pipes? thanks |
rayodunne Member Since: 17 May 2018 Location: Sudbury Posts: 41 ![]() ![]() ![]() |
This will likely work but I'm sure you can measure the wall thickness before ordering if not 1.5mm:
You could weld up each of the roll bars to make them solid and connect the oulet of the pump to the return and run the pump in a loop. Get the software for the ACE removed. Always listen to old people or when they die you will live on in ignorance.
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4531 ![]() ![]() ![]() |
^ Or, you can just fix it properly |
Yeah, ruin the vehicle or just do a simple, proper, fix to repair it. ![]() 2008 TDV8 - it was a labour of love and is much missed |
Simple is £ 4500 Always listen to old people or when they die you will live on in ignorance.
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5150 ![]() ![]() ![]() |
I suppose another simple solution would be, for people to buy something they can afford to repair if it breaks, rather than bodge everything up.
It not mine its the bloke next door ..2011 its as rusty as **** Always listen to old people or when they die you will live on in ignorance.
