Home > Maintenance & Modifications > RRS 2011 ACE pipe leak HELP
jig
2011 Range Rover Sport 3.0 TDV6 Autobiography Orkney Grey
Hi guys I have an ACE pipe leak behind the drivers wheel. The pipes are rusted quite bad. I had one last year and the garage I tool it to fitted a hydraulic pipe but ripped me off.
So thinking of doing this myself but need the help and support from the amazing folks on this site. Please see pics of where the leak is any advice on fixing and where I should make the cuts would be greatly appreciated.
Pics below (second pipe from the left)
Post #644017 Mon Sep 02 2024 6:28pm
jig
Post #644018 Mon Sep 02 2024 6:29pm
jig
Also is there anything I can paint onto the pipes to strengthen or prevent further rusting? Thanks
Post #644019 Mon Sep 02 2024 6:30pm
jig
Bump
Post #644046 Wed Sep 04 2024 5:47am
Pistnbroke
If its leaking you will have to replace it . A hydraulic pipe is only about £30.
The only coating for rust is Marine Epoxy..takes 24 hrs to set and soaks into the rust,( not the polyester fast setting fibreglass stuff) Always listen to old people or when they die you will live on in ignorance.
Post #644049 Wed Sep 04 2024 8:28am
There are a number of products that deal with rust. They generally convert the rust from iron oxide to a phosphate that doesn't corrode further. You then need to coat/paint the metal to stop further attacks. Only way to make the pipes stronger is to replace them. And as said, if it's leaking, it has to be replaced. 2012 SDV6 - it's missing a couple of cylinders
Post #644050 Wed Sep 04 2024 9:30am
jig
Thanks Piston I was thinking of cutting and fitting hydraulic pipe made up with compression fittings then painting all the rusted areas with the Marine Epoxy to prevent further weakness.
Post #644059 Wed Sep 04 2024 4:48pm
jig
Thanks RRSTDV8. I am hoping to cut section and replace with hydraulic pipe with compression fitting. Any specific product you recommend for the rusted pipes? thanks
Post #644060 Wed Sep 04 2024 4:51pm
rayodunne
Canada 2009 Range Rover Sport Supercharged Santorini Black
This will likely work but I'm sure you can measure the wall thickness before ordering if not 1.5mm:
https://www.fluidairfittings.co.uk/product...10x1-5-c6f 2009 Range Rover Sport Supercharged
Post #644090 Thu Sep 05 2024 7:05pm
Pistnbroke
You could weld up each of the roll bars to make them solid and connect the oulet of the pump to the return and run the pump in a loop. Get the software for the ACE removed. Always listen to old people or when they die you will live on in ignorance.
Post #644092 Thu Sep 05 2024 9:59pm
Disco_Mikey
^ Or, you can just fix it properly Rolling Eyes
Post #644120 Sat Sep 07 2024 11:56am
Yeah, ruin the vehicle or just do a simple, proper, fix to repair it. Censored 2012 SDV6 - it's missing a couple of cylinders
Post #644123 Sat Sep 07 2024 6:35pm
Pistnbroke
Simple is £ 4500 Always listen to old people or when they die you will live on in ignorance.
Post #644125 Sat Sep 07 2024 8:37pm
I suppose another simple solution would be, for people to buy something they can afford to repair if it breaks, rather than bodge everything up.
Post #644126 Sat Sep 07 2024 9:12pm
Pistnbroke
It not mine its the bloke next door ..2011 its as rusty as **** Always listen to old people or when they die you will live on in ignorance.
Post #644128 Sun Sep 08 2024 7:16am
