Home > Maintenance & Modifications > What trim clip do I need please?
Silverstone
United Kingdom 2012 Range Rover Sport Supercharged HSE Baltic Blue
This afternoon I notice that the nearside front door speaker casing (above the passenger electric window switch) is rattling. Upon inspection I notice that part of the yellow clip (see below) has snapped. Hence I need to source a replacement clip. Does anyone know what sort of clip I need and where I can get one please?
Thank you in advance.
 There is no replacement for displacement - W O Bentley
MY2013 5.0 Supercharged HSE L320
Post #635833 Fri Sep 15 2023 3:18pm
Google EYC106710 I think that's the one you need, unfortunate as I have a load here but 12000mls away Smile , same one's as used on the b/c and d post trims etc. as well.
Post #635844 Fri Sep 15 2023 11:57pm
Silverstone
Thank you Col - you are a gentleman! Ordered and hopefully easy to swap There is no replacement for displacement - W O Bentley
Post #635847 Sat Sep 16 2023 9:23am
Dead easy to change, old one just sort of pushes out sideways, just slide and push the new one in and it clips in positon, don't need to remove the speaker from the door panel either can slide it in in situ.
Post #635848 Sat Sep 16 2023 10:00am
Grimble
Highly recommend www.vehicleclips.co.uk
Very helpful to me recently. RRS HSE Dynamic SDV6 2014
Nemo mortalium omnibus horus sapit
Post #635930 Mon Sep 18 2023 10:13am
