Home > Maintenance & Modifications > What trim clip do I need please? |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4845 |
Google EYC106710 I think that's the one you need, unfortunate as I have a load here but 12000mls away , same one's as used on the b/c and d post trims etc. as well.
Fri Sep 15 2023 11:57pm |
Silverstone Member Since: 04 Sep 2014 Location: Towcester Posts: 180 |
Thank you Col - you are a gentleman! Ordered and hopefully easy to swap There is no replacement for displacement - W O Bentley
Sat Sep 16 2023 9:23am |
Dead easy to change, old one just sort of pushes out sideways, just slide and push the new one in and it clips in positon, don't need to remove the speaker from the door panel either can slide it in in situ.
Sat Sep 16 2023 10:00am |
Grimble Member Since: 21 Aug 2020 Location: Staffordshire Posts: 224 |
Highly recommend www.vehicleclips.co.uk
Mon Sep 18 2023 10:13am |
