Home > Technical > What Tyre Pressues?
Pistnbroke
United Kingdom 2009 Range Rover Sport TDV6 HSE Galway Green
What Tyre Pressues?
Using the standard pressures on the plate the vehicle needed continuous corrections on the steering wheel and the rear was a bit bouncy. Loaded for the holiday the back end calmed down .
So I reduced pressure to 33 all round and it was much improved. 255/50/19
What do you use and comments. Always listen to old people or when they die you will live on in ignorance.
The avatar is a picture of the man with a big cock.
Learned to 4x4 on 100 mile beach and Frazer Island QLD
Dont spend money on old cars you will never get it back
Post #635734 Mon Sep 11 2023 7:52am
Personaly I think 33psi in the rear is a bit low, I usally run mine at 36psi although I am on 275/45 x 21" wheel/tyre size.
Post #635735 Mon Sep 11 2023 8:03am
I run mine 36f / 39r normally but add to the rear if I'm going to load it and travel any distance. 255/55/19.
Have you had the alignment checked/adjusted? These things have adjustability in each corner so they need the right alignment check to ensure all is correct. 2012 SDV6 - it's missing a couple of cylinders
Post #635738 Mon Sep 11 2023 9:28am
Pistnbroke
I suppose it depend on the accuracy of the tyre pressure gauge ....... Always listen to old people or when they die you will live on in ignorance.
Post #635747 Mon Sep 11 2023 6:27pm
Pistnbroke
Post #635748 Mon Sep 11 2023 6:28pm
BJH1959
Portugal 2005 Range Rover Sport TDV6 HSE Cairns Blue
Hard to find any accurate air pump in a garage here yet alone precise, so I use my own at home - which is also helpful as regards the temperature of the tyre. (By the time I got to a garage the tyres were usually hot!)
2.4 front, and 2.6 rear for the 275/40/20s on my 2.7TDV6. Barrie.
2017-Jan 2024: 2005 RRS 2.7TDV6. Best car I ever had - until now!
Current: 2018 Ford Ranger Wildtrak 3.2
Post #635749 Mon Sep 11 2023 8:07pm
Yeah, have digital one in the car, and generally check mine after the car has been parked overnight.
Post #635759 Mon Sep 11 2023 10:35pm
