![]() | Home > Technical > What Tyre Pressues? |
Personaly I think 33psi in the rear is a bit low, I usally run mine at 36psi although I am on 275/45 x 21" wheel/tyre size.
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9135 ![]() ![]() ![]() |
I run mine 36f / 39r normally but add to the rear if I'm going to load it and travel any distance. 255/55/19.
Pistnbroke Member Since: 22 Sep 2020 Location: rugby Posts: 466 ![]() ![]() ![]() |
I suppose it depend on the accuracy of the tyre pressure gauge ....... Always listen to old people or when they die you will live on in ignorance.
BJH1959 Member Since: 25 Mar 2017 Location: Paredes de Coura, Portugal Posts: 410 ![]() ![]() ![]() |
Hard to find any accurate air pump in a garage here yet alone precise, so I use my own at home - which is also helpful as regards the temperature of the tyre. (By the time I got to a garage the tyres were usually hot!)
Yeah, have digital one in the car, and generally check mine after the car has been parked overnight.
