Home > Maintenance & Modifications > 2012 RRS 3.0 tdv6 ZF8 gearbox sump pan and filter change
ReluctantGardner
United Kingdom 2012 Range Rover Sport 3.0 TDV6 HSE Santorini Black
As a newby to RRS ownership I would firstly like to thank all the advice on this forum that I have used to carry out a number of modifications and repairs Thumbs Up
Having purchased the pan and oil to undertake the gearbox sump/filter change, I stripped off the shields to find myself with no access to four bolts on the pan, my L shaped T40 is not long enough to reach the heads between the crossmember and the pan and the T40 socket is too big to fit in the space. Does anyone know of a way to gain access to these bolts to remove the pan and also is there enough space between the pan and the crossmembers to remove/reinsert the new pan or should I just replace the oil?
Post #632877 Fri May 05 2023 9:22am
Nilrem280
United Kingdom 2010 Range Rover Sport TDV8 HSE Nara Bronze
As a side note the ZF8 has a thermostatic valve that needs to be a temp for it to open and be able to drain and replace the fluid.
I don't have the correct temp at hand but you will need someway of measuring the ATF temp whilst your doing the job.
Post #632880 Fri May 05 2023 9:33am
I wouldn't both changing the pan and filter, just have the fluid mega-flushed. That way you change all of the oil not just a percentage of it. 2012 SDV6 - it's missing a couple of cylinders
Post #632883 Fri May 05 2023 9:55am
ReluctantGardner
Thanks, I knew about the required temp for filling to level but wasn't aware of this requirement for draining, so will research this before starting, I have a Topdon 600s OBD reader which allows access to live data so should be able to use this for both.
I probably should have stated the mileage is around 55k miles, as I know there's lots of debate around when the right time is to carry out the service, also i have no issues with the gearbox, just wanted to do a bit of preventative maintenance.
Post #632884 Fri May 05 2023 9:55am
ReluctantGardner
Is there a way of emptying the torque converter, I seem to remember it involved starting the engine for 20 seconds during the drain down, although I wasn't sure about trying it if the gearbox was going to shriek and grind to a halt!
Post #632885 Fri May 05 2023 9:59am
55k miles is about spot on for mileage for the fluid change. Get it flushed, not just emptied and refilled. The empty/refill method doesn't change all of the oil even if you do it twice. The flush does.
Some suggest that the empty-refill method is ok because it refreshes the additives in the oil (the important bit), but a flush does that for all of the oil so why not do that instead? My SDV6 has been flushed twice and is now on 143k miles. Will probably get it done again at the next service. 2012 SDV6 - it's missing a couple of cylinders
Post #632886 Fri May 05 2023 10:00am
Again, a flush does this without the risk of killing your gearbox. Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #632887 Fri May 05 2023 10:01am
ReluctantGardner
Cheers, I'll look up Bodsy, I understand he's the man for this job Thumbs Up
Post #632909 Sat May 06 2023 10:07am
