![]() | Home > Maintenance & Modifications > 2012 RRS 3.0 tdv6 ZF8 gearbox sump pan and filter change |
ReluctantGardner Member Since: 20 May 2021 Location: Derbyshire Posts: 6 ![]() ![]() ![]() |
As a newby to RRS ownership I would firstly like to thank all the advice on this forum that I have used to carry out a number of modifications and repairs |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9130 ![]() ![]() ![]() |
I wouldn't both changing the pan and filter, just have the fluid mega-flushed. That way you change all of the oil not just a percentage of it. 2012 SDV6 - it's missing a couple of cylinders
Thanks, I knew about the required temp for filling to level but wasn't aware of this requirement for draining, so will research this before starting, I have a Topdon 600s OBD reader which allows access to live data so should be able to use this for both.
Is there a way of emptying the torque converter, I seem to remember it involved starting the engine for 20 seconds during the drain down, although I wasn't sure about trying it if the gearbox was going to shriek and grind to a halt! |
55k miles is about spot on for mileage for the fluid change. Get it flushed, not just emptied and refilled. The empty/refill method doesn't change all of the oil even if you do it twice. The flush does.
Again, a flush does this without the risk of killing your gearbox. ![]() 2008 TDV8 - it was a labour of love and is much missed |
Cheers, I'll look up Bodsy, I understand he's the man for this job |
