![]() | Home > Maintenance & Modifications > 2012 5.0s/c timing chain issues? |
SuperC Member Since: 24 Feb 2016 Location: Midhurst, West Sussex Posts: 90 ![]() ![]() ![]() |
Hi All,
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5151 ![]() ![]() ![]() |
Nothing to do with oil viscosity provided you use 5w20 oil, it was a problem with the chain tensioners wearing, they did start fitting revised tensioner on later engines, if your car is a MY12 on, it should have the revised one's fitted if it is after Vin.no CA759577 you should be o.k. Personally I would just ignore all the scare mongering merchants, and all the crap spouted online by the ''armchair experts'' if you believe all that rubbish every 3.0L built is going to self destruct as well, but that said anything mechanical can fail.
Thanks Col. Checking that vin now. That was the key piece of info I was looking for. Cheers,
It is not unknown for the supercharger torsional isolator to wear and or the isolator spring to break which would also sound like a knock or rattle from the front of the engine, however that is easy enough to check, just drop the s/c belt off, run the engine and if noise goes that's the problem.
Thanks. I will get this checked. I've looked at the vin and |
You mean its not true that all the 3.0L cranks are made of cheese? I'm sure I read that on the internet so, it must be true........ ![]() Stuart. RRS 2012 HSE 5.0 S/C Zermatt Silver. RRS 2005 4.2 S/C First Edition Rimini Red- Gone but not forgotten Defender 2005 TD5 XS Black - Gone Freelander 2006 HSE Blue - Gone |
