Home > Maintenance & Modifications > 2012 5.0s/c timing chain issues?
SuperC
United Kingdom 2012 Range Rover Sport Supercharged Zermatt Silver
Hi All,
So, I”ve just freaked myself out with notions of failing timing chain tensioners and my v8 exploding. Thud
I’ve done some internet searches and, to me, it’s not conclusive. I’ve seen something about a class action in the US but, not the outcome. I’ve seen another thing saying it’s all about oil viscosity. Is this an actual issue I should consider taking action on to avoid? Has anyone else had the problem and fixed it? I think I’m just getting freaked out now my baby is over 10 years old and out of warranty. Seems like it’s repeatedly ready to cost me a grand to fix at any given moment and that’s without the tensioner actually failing.
What’s the collective wisdom on this? What do you think should be the course of action? Cheers,
Stuart.
RRS 2012 HSE 5.0 S/C Zermatt Silver.
RRS 2005 4.2 S/C First Edition Rimini Red- Gone but not forgotten
Defender 2005 TD5 XS Black - Gone
Freelander 2006 HSE Blue - Gone
Post #632785 Sun Apr 30 2023 11:04pm
Nothing to do with oil viscosity provided you use 5w20 oil, it was a problem with the chain tensioners wearing, they did start fitting revised tensioner on later engines, if your car is a MY12 on, it should have the revised one's fitted if it is after Vin.no CA759577 you should be o.k. Personally I would just ignore all the scare mongering merchants, and all the crap spouted online by the ''armchair experts'' if you believe all that rubbish every 3.0L built is going to self destruct as well, but that said anything mechanical can fail.
Post #632786 Mon May 01 2023 12:00am
SuperC
Thanks Col. Checking that vin now. That was the key piece of info I was looking for. Cheers,
Stuart.
Post #632788 Mon May 01 2023 8:17am
Crs
England 2013 Range Rover Sport Supercharged Autobiography Firenze Red
I used to have the same model, mine had just over 70000 miles on the clock, no rattles but my independent Land Rover garage said they had seen quite a few with chain rattles once they got over 70000 miles. Maybe get someone who knows to have a listen.
Post #632790 Mon May 01 2023 8:30am
It is not unknown for the supercharger torsional isolator to wear and or the isolator spring to break which would also sound like a knock or rattle from the front of the engine, however that is easy enough to check, just drop the s/c belt off, run the engine and if noise goes that's the problem.
Post #632794 Mon May 01 2023 9:08am
SuperC
Thanks. I will get this checked. I've looked at the vin and Censored Censored Censored Its before this number so, not the upgraded one. Big Cry Big Cry Cheers,
Stuart.
Post #632795 Mon May 01 2023 9:15am
SuperC
You mean its not true that all the 3.0L cranks are made of cheese? I'm sure I read that on the internet so, it must be true........ Whistle Cheers,
Stuart.
Post #632796 Mon May 01 2023 9:44am
