![]() | Home > General (L494) > Parking Sensor Fault |
2 RRS Member Since: 04 Sep 2016 Location: Shropshire Posts: 226 ![]() ![]() ![]() |
I had this exact fault (albeit intermittent) and the DTC reported either the drivers side outer sensor or a bad connection (Gnd I think). Tried a spare good sensor and still the same, so had a look and the front bumper wiring loom multi-plug under the nearside front wheel arch liner and found it not fully seated. Quick unplug, contact spray and re-plug and all has been good ever since!
Punkawallah Member Since: 04 Sep 2018 Location: Salisbury Posts: 160 ![]() ![]() ![]() |
Thanks Mike - I will check that and see if it helps! 2014 L494 V8 s/c Autobiography Dynamic |
