Home > General (L494) > Parking Sensor Fault
Punkawallah
United Kingdom 2013 Range Rover Sport Supercharged Autobiography Adriatic Blue
Hi all,
So I noticed a "parking aid not available, please consult your dealer" sign on the dash a few times recently and a long beep when put into reverse. Cameras still work but front and rear parking sensors don't.
I took it to my local garage who plugged it in and it said the front driver's side one was faulty so I replaced it with a new one myself.
Sadly it hasn't fixed the issue - the question I'm asking here is do I need to reset the system somehow - i.e. unplug battery for 20 mins?
Anyone got any experience of this?
Thanks in advance! 2014 L494 V8 s/c Autobiography Dynamic
Post #632298 Thu Apr 13 2023 1:00pm
2 RRS
United Kingdom 2013 Range Rover Sport SDV6 Autobiography Bourneville
I had this exact fault (albeit intermittent) and the DTC reported either the drivers side outer sensor or a bad connection (Gnd I think). Tried a spare good sensor and still the same, so had a look and the front bumper wiring loom multi-plug under the nearside front wheel arch liner and found it not fully seated. Quick unplug, contact spray and re-plug and all has been good ever since!
Do you have a DTC to refer to?
Hope this is of some help!
Mike
Post #632318 Thu Apr 13 2023 6:56pm
Punkawallah
Thanks Mike - I will check that and see if it helps! 2014 L494 V8 s/c Autobiography Dynamic
Post #632414 Mon Apr 17 2023 1:37pm
