![]() | Home > General > Introductions |
skid1963 Member Since: 24 Mar 2018 Location: Snodland Posts: 224 ![]() ![]() ![]() |
Check out user Lrstaylor posts, do a search for them.....he had a similar problem to you 2015 L494 SDV6 3.0 HSE Loire Blue
karlos01 Member Since: 02 Jan 2022 Location: norfolk Posts: 309 ![]() ![]() ![]() |
had running lean on bank one and two found I had slight blow from manifold gasket and changed the lamba sensors |
Kevinjrob72 Member Since: 31 Mar 2023 Location: Somerset Posts: 5 ![]() ![]() ![]() |
Thanks i will check out his thread. Have ruled out vacuum leaks and when I check on my scanner the lambda sensors on both sides read the same but feel trims are +19% on bank 1 -3% on bank 2 so something fishy going on. It failed MoT after the rebuild with high CO but have fixed vacuum leaks since then. |
Hi All. Wonder if I could please pick the forums brain to decipher readings taken from my RRS 4.2. Problem as stated above. When looking at the data on the O2 sensors bank 1 states closed loop control off bank 2 closed loop control on. Sensor 2 bank 1 have a voltage of 1.78 constant and the associated fuel trim was 0 percent, then after a period of time dropped to 0.1v and pushed the asociated fuel trim into a negative number. Sensor 2 bank 2 showed between .6 and .8 dependant on revs/ throttle with an associated fuel trim in the 1 - 3 % range. Am I right in thinking this sounds like sensor 2 bank 1 has a bad connection or is busted / gummed up? Thanks in advance for your help |
kevinjrob72
Nope no lpg just good old petrol. Work completed so far (as it probably something I did:)
Oh and when it failed MoT on emissions it had high co but hydrocarbons and lambda were fine. But since then I have fixed a couple of vacuum leaks. |
you might of cured it like I posted I changed all 4 lamba sensor
