Home > General > Introductions |
skid1963 Member Since: 24 Mar 2018 Location: Snodland Posts: 189 |
Check out user Lrstaylor posts, do a search for them.....he had a similar problem to you 2006 L320 4.2 Supercharged
Fri Mar 31 2023 5:23pm |
karlos01 Member Since: 02 Jan 2022 Location: norfolk Posts: 286 |
had running lean on bank one and two found I had slight blow from manifold gasket and changed the lamba sensors |
Fri Mar 31 2023 6:10pm |
Kevinjrob72 Member Since: 31 Mar 2023 Location: Somerset Posts: 5 |
Thanks i will check out his thread. Have ruled out vacuum leaks and when I check on my scanner the lambda sensors on both sides read the same but feel trims are +19% on bank 1 -3% on bank 2 so something fishy going on. It failed MoT after the rebuild with high CO but have fixed vacuum leaks since then. |
Fri Mar 31 2023 6:38pm |
Hi All. Wonder if I could please pick the forums brain to decipher readings taken from my RRS 4.2. Problem as stated above. When looking at the data on the O2 sensors bank 1 states closed loop control off bank 2 closed loop control on. Sensor 2 bank 1 have a voltage of 1.78 constant and the associated fuel trim was 0 percent, then after a period of time dropped to 0.1v and pushed the asociated fuel trim into a negative number. Sensor 2 bank 2 showed between .6 and .8 dependant on revs/ throttle with an associated fuel trim in the 1 - 3 % range. Am I right in thinking this sounds like sensor 2 bank 1 has a bad connection or is busted / gummed up? Thanks in advance for your help |
Sat Apr 01 2023 1:38pm |
kevinjrob72
Sat Apr 01 2023 4:05pm |
Nope no lpg just good old petrol. Work completed so far (as it probably something I did:)
Sat Apr 01 2023 5:28pm |
Oh and when it failed MoT on emissions it had high co but hydrocarbons and lambda were fine. But since then I have fixed a couple of vacuum leaks. |
Sat Apr 01 2023 5:36pm |
you might of cured it like I posted I changed all 4 lamba sensor
Sat Apr 01 2023 5:56pm |
