Home > General (L494) > Steering rack failure
Dobby
Hi all, Help!!
I've got the dreaded electronic power steering unit failure. I can see the unit is loose form the steering rack, and 2 of the 3 bolts holding it on have sheared off.
Is it easy enough to just take the EPS off, remove the broken bolts and refit, or is there likely to be more damage requiring open wallet surgery?
Thanks in advance,
Dobbles. MY15.5 HSE
MY13 110
MY87 90 (ex-mod) (for sale)
Post #630298 Thu Jan 26 2023 5:33pm
Dobby
Hi, everyone, so a bit of an update which might pre useful for someone in the future.
After some Googling, I’ve discovered that this failure is huge! In more ways than one.
The failure is caused by one, two or all three of the bolts that secure the EPAS drive motor to the steering rack. The bolts are susceptible to salt damage which weakens them. They eventually snap, causing a catastrophic lose of steering. Luckily we were on the drive, so noticed straight away.
It’s such a common fault on Evoque and Disco Sport, that JLR provide a perpetual warranty repair, and is subject to a recall in the US and Canada. The problem was featured on the One Show in the UK, too.
Now, JLR and local dealership said they’d never heard of this on a RRS, but the part is identical to that used in the Evoque and DS. My 3rd party warranty company had heard of this, and the guy I spoke to knew it was quite common on RRS too.
But, it’s going to cost a lot to get repaired. New part if circa £2000, and labour to fit will be similar given the amount of work needed. Currently waiting for a complete estimate on the job.
So, there you have it; a couple of failed bolts which have a huge price tag. Sad day! MY15.5 HSE
MY13 110
Post #630419 Sun Jan 29 2023 9:57pm
Disco_Mikey
Sadly, not uncommon (albeit on a L405)
It's nowhere near the labour estimate though Shocked
Post #630422 Mon Jan 30 2023 12:00am
DM, would there be any advantage if this is bit of a common occurrence now to pre-empt it and replace the bolts with 304 or 316 grade stainless steel bolts, although they would eventually corroded but not to the degree of steel ones , might save someone a big bill, only a thought.
Post #630423 Mon Jan 30 2023 3:47am
Disco_Mikey
I know there were a few places offering this for the Evoque/DS racks
Those cars are now excluded from the recall due to "modifications"
(Assuming JLR will extend the recall to all models)
Also, if you snap the bolts while replacing, that's a whole world of pain
Post #630424 Mon Jan 30 2023 7:09am
Dobby
Confused Gulp! More, or less? MY15.5 HSE
MY13 110
Post #630453 Mon Jan 30 2023 10:59pm
Disco_Mikey
Much less Laughing Thumbs Up
Post #630456 Tue Jan 31 2023 7:49am
Luke
England 2005 Range Rover Sport Supercharged Java Black
Hi, I have just had this exact same problem on my L405, bolts snapped and the motor fell out, no warnings on dash and the motor was still spinning with each turn of the wheel. My local garage managed to drill out the broken bolts and re attach it but it doesn't work at all now, does anyone know if this now needs some sort of reset? !st Edition RRS S/C, Black on Black.
RRS HSE, Java, Alpaca, Bluetooth, Dynamic Pack, SC Grill, Black Badges, tints all round.
(NOW SOLD)
Ex D3 TDV6S owner
Post #630490 Wed Feb 01 2023 12:22pm
Iomegas
United Kingdom 2013 Range Rover Sport 3.0 TDV6 HSE Santorini Black
I remember being at my LR Independent last year and I was chatting about how busy they were with the lad on the front desk stated that they were getting a good few RR with the exact problem as described.He basically said the cheap quality bolts were the problem and blamed LR cost cutting rather than paying that little extra for decent quality bolts.
Post #630496 Wed Feb 01 2023 4:05pm
I'm surprised that LR are making this a perpetual warranty issue rather than just swapping the bolts out for decent quality items as a one off job. Surely that would be cheaper than dealing with full failures as warranty claims. 2012 SDV6 - it's missing a couple of cylinders
Post #630501 Wed Feb 01 2023 6:57pm
jcchief
United Kingdom 2013 Range Rover Sport 3.0 TDV6 HSE Lux Rimini Red
steering Aluminum bolt failure
Hs anyone noticed the bolts tend to fail in winter and there is no corrosion on the bolts.
It happened to me 9 December 2023 overnight temp -4c on the driveway. pressed the ignition and the steering wheel started to whine and vibrate with no input from us, so the bolt must have sheared during the night.
The AA said they get loads of calls for this fault.
Post #639261 Tue Jan 30 2024 12:56pm
jcchief
My 2015 range rover sport has the same steering unit as Discovery sport 2015 to 2017 , however its not covered by the fix on failure extended warranty for Evoque 2012-2017 and Disco sport.
Range rover cant explain why RRS owners are discriminated against and stone walling by not replying to complaints from long term customers. I have had Jags and RR for 40 years and most probably spent £600k on their cars.
This repair at £3000 represents 20% of the cars value
extremely bad way to do business and they put profit over safety.
Post #639263 Tue Jan 30 2024 1:03pm
Dobby
Keep the pressure on LR Customer Service for your case
To be escalated. They may well still pay. MY15.5 HSE
MY13 110
Post #639264 Tue Jan 30 2024 1:31pm
jcchief
Thanks for the suggestion , however i most probably spent 2 hours on the phone with them over last 6 weeks.
originally told by RR customer service 13 December that if i took it to a RR dealer and if it was the same fault they may cover the RRS as a gesture of good will.
Knowing that it was the same fault I Paid for a recovery truck to take it to RR Stoke 15 December and they filled in the form and the RR came back on 30 December and said vin number isn't included, obviously sticking with the usual fob off scrip, as my car is a RR sport.
why should we be discriminated against when Evoque and Disco sports get a fix on failure?
I Followed up with a 2 lengthy calls and finally detailed email to the CEO and customer service highlighting the profit over safety issue and why the discrimination but nothing back since 10 days.
When the fault happened the AA technician pulled out the bolt which had absolutely no sign of corrosion, to me the shear looked like stress fatigue and my first reaction was why the hell did they use an aluminum bolt? then realised they put bi metalic corrosion over having a stronger tensile bolt. The new bolts are steel but coated to stop the bi metalic corrosion with the aluminum pump housing. This is what they should have done as the original spec. The theory of saltwater corrosion causing the fault does not appear to be common.
Post #639267 Tue Jan 30 2024 2:12pm
Dragon31
Another Model bites the dust
the same fault has just happened on my Range Rover Vogue (2016). Motor completely detached as all 3 bolts failed. Hate to think what would have happened if I'd been on the motorway or a busy roundabout. Same response from JLR, no recalls on your VIN and you're on your own!
Going to escalate with complaint and pictures on all socials - just to be a pain if nothing else. £2,500 for a new rack and 3 hours labour for a manufacturing fault seems a bit steep.
Post #639320 Fri Feb 02 2024 6:25pm
