Home > Maintenance & Modifications > Ace pipes repair |
karlos01 Member Since: 02 Jan 2022 Location: norfolk Posts: 289 |
the pipes can be made by hydraulic pipe specialists I got local company to make mine I just took the old ones in and they use them as templates for new ones as they will have all the fittings and info on the old pipes to match new ones |
Sat Jan 21 2023 7:47am |
Hightimo Member Since: 08 Jan 2022 Location: Liverpool Posts: 64 |
Great thanks - is the best thing to do just cut the old mega section at a decent point and then use a compression joint then at that point , and hopefully get the other end re-used when the pipes are made up - think it is the pipe from the roll bar and then runs down the os chassis , has a flexi in it to just after it leaves the roll bar if I remember right |
Sat Jan 21 2023 10:04am |
‘Metal section’ not mega !!! |
yeah should be ok but someone who knows more might answer better |
Sun Jan 22 2023 9:22pm |
