Home > Maintenance & Modifications > Ace pipes repair
Hightimo
United Kingdom 2007 Range Rover Sport TDV8 HSE Zermatt Silver
Ace pipes repair
I am due to replace some on the ace pipes on my 2007 tdv8 l320 - has anyone had any success in repairing pipes rather than just replace ? Can replacement pipes be made up at hydraulic pipe specialists ? And can 10mm plumbing compression joints be used ?
Post #630075 Fri Jan 20 2023 11:52pm
karlos01
the pipes can be made by hydraulic pipe specialists I got local company to make mine I just took the old ones in and they use them as templates for new ones as they will have all the fittings and info on the old pipes to match new ones
Post #630078 Sat Jan 21 2023 7:47am
Hightimo
Great thanks - is the best thing to do just cut the old mega section at a decent point and then use a compression joint then at that point , and hopefully get the other end re-used when the pipes are made up - think it is the pipe from the roll bar and then runs down the os chassis , has a flexi in it to just after it leaves the roll bar if I remember right
Post #630085 Sat Jan 21 2023 10:04am
Hightimo
‘Metal section’ not mega !!!
Post #630086 Sat Jan 21 2023 10:04am
karlos01
yeah should be ok but someone who knows more might answer better
Post #630136 Sun Jan 22 2023 9:22pm
