Home > Off Topic > IP Address
Page 3 of 6 <123456>
Brian Mason wrote:
JayMann wrote:
How do you know he was in prison did you meet in there??
No, Ivery told me.., they're ALL convicts down under!!! Whistle
Anyway, I thought it was mandatory for all northerners to go to prison for joy-riding or burglary? Rolling Eyes
I thought they where all Gay ?? RRS TDV6 Gone but still around
Post #99420 Sun Apr 01 2007 2:06pm
WOODY179
Jay,
Just been having a look at my router settings and it would appear that it is possible to get a permanent IP number, just depends on your ISP provider.
In my router (Netgear DG834PN) it says the following:
Internet IP Address
If you log in to your service or your ISP did not provide you with a fixed IP address, the Router will find an IP address for you automatically when you connect. Select Get Dynamically From ISP.
If you have a fixed (or static IP) address, your ISP will have provided you with the required information. Select Use Static IP Address and type the IP Address, Subnet Mask and Gateway IP Address into the correct fields.
For example:
IP Address: 24.218.156.183
Subnet Mask: 255.255.255.0
Gateway IP Address: 24.218.156.1
Post #99421 Sun Apr 01 2007 2:06pm
I'll have to pop over later and see if i can do that with my one as well thanks Thumbs Up RRS TDV6 Gone but still around
Post #99427 Sun Apr 01 2007 2:10pm
ivery819
quote BM "they're ALL convicts down under"
Don't like prisons....full of queers don't you know Mad
Post #99430 Sun Apr 01 2007 2:13pm
Brian Mason
United Kingdom 2012 Range Rover Sport SDV6 HSE Sumatra Black
No, I dont know.., did JAY tell you? Whistle MY12 SDV6 HSE Sumatra/Ebony/Piano/Sidesteps/Privacy/Overfinch Olympus/JLR DRLs
Post #99433 Sun Apr 01 2007 2:17pm
Jay - you just need a dynamic DNS
go to www.dyndns.com - register the shop pc there and give it any name you want - i.e. jayman.dyndns.org or similar.
Everytime your shop pc logs in it contacts dyndns and updates its current ip
then from home, instead of putting 87.174.**.** etc etc, you just type in jayman.dyndns.org - it will then just connect upto the latest ip address for that domain
Hope that makes sense and helps
Post #99444 Sun Apr 01 2007 2:37pm
Kaine the only way i can see the CCTV cameras is with the software that i got with them not over an Internet browser
So i have to put the ip in to that then that log's in to the CCTV switch direct RRS TDV6 Gone but still around
Post #99454 Sun Apr 01 2007 2:48pm
Jay - are you sure you cant use a name in place of the ip address - which software is it?
Post #99455 Sun Apr 01 2007 2:50pm
anyway - not a problem - once you've set the computer up at the shop, you can just login to dyndns.com at home and see the ip address
Post #99457 Sun Apr 01 2007 2:51pm
Never tried mate
I did set a dyndns account but don't know if it will work with the name thing
http://www.dedicatedmicros.com/uk/regional_home.php RRS TDV6 Gone but still around
Post #99459 Sun Apr 01 2007 2:54pm
that doesn't matter so much though - you can still just login from home and check the latest ip and then use that - isn't that what you wanted to do?
Post #99462 Sun Apr 01 2007 2:56pm
Cool that what i want
But do i need to download software on to the pc in the shop i remember setting this up in the router so i'm guessing it will do it self then? RRS TDV6 Gone but still around
Post #99464 Sun Apr 01 2007 2:57pm
Yep thats all Very Happy RRS TDV6 Gone but still around
Post #99465 Sun Apr 01 2007 2:58pm
Are you all sorted out Jay? The Dyndns route is the way to do it or alternatively, just get your ISP to allot that connection a static IP (which they may or may not charge for). The static IP method obviously involves no work at your end other than to phone the ISP, which might suit you Laughing
Post #99645 Mon Apr 02 2007 9:27am
How do i do this then do i have to download software on to the pc of the IP i want?? RRS TDV6 Gone but still around
Post #99648 Mon Apr 02 2007 9:35am
