Home > Off Topic > IP Address
Page 2 of 6 <123456>
Thaans for that Aljo
But it's not what i was after i know how to get in to the Modem so you can adjust things
I need to get to the CCTV via the modem
If i go over there and go to www.whatismyip.co.uk i get the ip and put that ip in to the software over here i can see the cameras but the IP changes ever 2/3 days so i have to pop over and get it.
Save me going over is there i site where this ip can be updated save me going over to the shop to find out what it is? RRS TDV6 Gone but still around
Post #99380 Sun Apr 01 2007 1:18pm
aljo
hows this jay ?
www.ezwatchip.com/how_to_setup_remote_access.pdf
Post #99382 Sun Apr 01 2007 1:23pm
I have all the software to view the CCTV just need some thing that will update the IP address when ever it changes to a site or email me! RRS TDV6 Gone but still around
Post #99387 Sun Apr 01 2007 1:31pm
aljo
you need to talk to bodie or doyle then jay Embarassed
Post #99393 Sun Apr 01 2007 1:33pm
ivery819
Who or what is changing it every couple of days ?
Post #99394 Sun Apr 01 2007 1:34pm
Ok then mate thanks for your help any way!! Thumbs Up RRS TDV6 Gone but still around
Post #99395 Sun Apr 01 2007 1:34pm
The ISP is Mad Mad RRS TDV6 Gone but still around
Post #99396 Sun Apr 01 2007 1:35pm
ivery819
If you are paying for it why can't they tell you the new address when they change it ?
Post #99398 Sun Apr 01 2007 1:38pm
Don't know why they do it
But it's pi Censored ing me right off i when over to get it the other day 2 hours later it Censored changed RRS TDV6 Gone but still around
Post #99399 Sun Apr 01 2007 1:40pm
ivery819
They cycle the addresses mainly as a security thing and it probably happens automatically.
Under normal circumstances you would have site access to the modem .....so no problem
Do you have any access to the modem from your end after its' address is changed?
Post #99400 Sun Apr 01 2007 1:45pm
Brian Mason
United Kingdom 2012 Range Rover Sport SDV6 HSE Sumatra Black
aljo wrote:
Finding the cable modem's address
Most DOCSIS cable modems have two IP addresses:
a customer-side IP address used on the ethernet/USB socket to which the user connects;
an ISP-side IP address used on the CATV socket to which the ISP's network connects.
The customer-side IP address of a DOCSIS cable modem is normally 192.168.100.1. For 3Com Tailfins with early firmware versions it was 149.112.50.65. Firmware can be automatically updated by your cable operator down the cable, so by the time you read this, most Tailfins will have been updated to use the standard address. The 3Com CMX does not have a customer-side IP address.
The IP address 192.168.100.1 will be present even if no web diagnostics are offered on that address.
The cable modem IP address 192.168.100.1 is not in the same sub-net as the user's PC. So, when trying to send to 192.168.100.1, the user PC's IP stack will normally route the packet to the Default Gateway address at the UBR. Since no routes exist to the private address 192.168.100.1 (and there are multiple instances of this IP address on any one CATV segment), the UBR drops the packet. This would mean that in theory the PC could never talk to the cable modem. However, the Surfboard, the 3Com Tailfin, and the ntl:home 100/120 are capable of sniffing the passing traffic through the transparent bridge to intercept any packets addressed to themselves. This only works when the bridge is open, so the cable modem diagnostics cannot be read when the cable modem is booting up or failing to remain in contact with the UBR.
For cable modems other than the Surfboard, Tailfin and ntl:home 100/120, and for the Surfboard/Tailfin when their bridge is closed, the only way to communicate with them is:
reconfigure the PC by disabling DHCP and manually assigning an IP address 192.168.100.xx, where xx is in the range 2-254, sub-net mask 255.255.255.0, and Default Gateway 192.168.100.1. This has the disadvantage of being incompatible with normal in-service usage; or
add a secondary IP address to the PC's network interface, leaving the primary IP address to be allocated by DHCP. The secondary IP address should be 192.168.100.xx where xx is in the range 2-254, with sub-net mask 255.255.255.0. The procedure for adding secondary IP addresses depends on operating system: for Windows 9x/ME it can be done only by editing the Registry, see http://support.microsoft.com/support/kb/articles/Q156/7/72.asp.
Note that, with the Surfboard and ntl:home 100/120, when the cable modem is not online to the cable operator's network, it runs an internal DHCP server which automatically gives the PC an IP configuration on the 192.168.100.xx sub-net to enable the PC to communicate with the cable modem on 192.168.100.1. Whistle
Bloody hell.., I'm amazed aljo. And I thought you were a thick nothern Censored ? Now you're just a plain northern Censored who's clearly learnt a lot in prison??? Whistle MY12 SDV6 HSE Sumatra/Ebony/Piano/Sidesteps/Privacy/Overfinch Olympus/JLR DRLs
Post #99402 Sun Apr 01 2007 1:51pm
Just asked this man in the shop that a bit of a PC boff and he said it can't be done RRS TDV6 Gone but still around
Post #99405 Sun Apr 01 2007 1:54pm
Brian Mason
So aljo is back to being a thick northern Censored that learned NOTHING in prison? Whistle MY12 SDV6 HSE Sumatra/Ebony/Piano/Sidesteps/Privacy/Overfinch Olympus/JLR DRLs
Post #99411 Sun Apr 01 2007 2:01pm
How do you know he was in prison did you meet in there?? RRS TDV6 Gone but still around
Post #99414 Sun Apr 01 2007 2:02pm
Brian Mason
No, Ivery told me.., they're ALL convicts down under!!! Whistle
Anyway, I thought it was mandatory for all northerners to go to prison for joy-riding or burgalry? Rolling Eyes MY12 SDV6 HSE Sumatra/Ebony/Piano/Sidesteps/Privacy/Overfinch Olympus/JLR DRLs
Post #99419 Sun Apr 01 2007 2:05pm
