![]() | Home > Maintenance & Modifications > Brembo front Calipers |
AndyCHO Member Since: 23 Dec 2021 Location: Wodonga Posts: 125 ![]() ![]() ![]() |
Hi all
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5132 ![]() ![]() ![]() |
4 pot Brembo's 360mm discs, 6 pot Brembo's are 380mm discs, not sure they ever fitted 4 pots on the facelift L320 unless maybe the last of the TDV8's, and yes the 6 pots from a L494 will fit the L320. Although you may need the larger backplate from the S/C L320 although some say the original can be used although clearance is a bit tight.
Thanks for that... these are definitely 6 pot based on this picture.
My s/c has 6 pots and they are defiantly 380mm discs, 99.99% certain the add is wrong at 360mm.
Cheers Col
Yes, but I have read people have managed to use the original one's when doing the conversion, although they are a little tight for clearance.
I finally got around to the task of cleaning up my eBay purchased 6 pot Brembos, ordered in some Brembo stickers and High temp caliper paint... after much cleaning and wire brushing, masking etc I am pretty happy with the results.
TheWojtek Member Since: 08 May 2015 Location: Poznań, Poland Posts: 748 ![]() ![]() ![]() |
For the same mod I used the Brembo pads and while they initially were quite dusty, the things settled and it is OK now. Thought about EBC Yellows, but since it is an upgrade and it could have gone wrong, I decided to try the cheaper Brembos first and move to EBC only if I need to. Still undecided after a month, satisfied with Brembos but I didn't do any proper motorway travels. Regards etc.,
EBC yellow for £160 is about half the price I got here, what's your source? Regards etc.,
3hcp Member Since: 04 Nov 2021 Location: Devon Posts: 81 ![]() ![]() |
EBay
DP42161R for the rear £100 2015 RRS DIESEL HYBRID |
I think you may find that's the wrong part number for the rears on a L320 should be DP42068.
Just quoted for my l494 2015 2015 RRS DIESEL HYBRID |
Certainly not cheap here in Australia... between A$500 and A$620 just for the fronts.
