![]() | Home > General > Transfer box-diff or torque convertor |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9138 ![]() ![]() ![]() |
https://www.rrsport.co.uk/gallery/albums/u...AA0CC7.MOV
Hodson91 Member Since: 09 Jan 2024 Location: Washington, Tyne and Wear Posts: 26 ![]() ![]() ![]() |
Hi did you ever get to the bottom of this bud?
DaftRascal Member Since: 08 Nov 2022 Location: Ayrshire Posts: 28 ![]() ![]() ![]() |
Yes, I did. Applogies for not updating the thread It was the new Propshaft which was at fault. The splines
I think i have the same noise. Like a rotational dunk dunk dunk
Yes, the rear section. I bought the faulty one from Amazon for £169 and it was on perhaps 4-5 weeks. Reason for changing it was the centre bearing/bushing was away. Genuine RR prop back on it now though. |
I could replicate the noise by turning at the propshaft by hand underneath the car. Not as loud or definitive but it gave clear indication. |
Thanks for getting back to me i will have a look
That sounds the exact same issue as I had. I was 100% convinced it was the front end somewhere. When under the car and twisting at the propshaft by hand I couldn't get it to make the exact noise or even really feel much play but I did get the hollow 'tingy' strange noise for like 1 click if that makes sense? |
Yes i didnt feel much play in mine to be honest and i cant get it to fault whilst i run it on the ramp as it needs to be under load.
Under load was when I noticed it most. At end up it was quite distinct. I'm sure that will be the issue with yours as well. |
I notice the noise on mine the most in reverse to be honest. As im reversing into my parking space at home. Its safe to say that i was very annoyed when i heard it the day i replaced the front diff |
