Home > General > Transfer box-diff or torque convertor
DaftRascal
United Kingdom 2009 Range Rover Sport TDV8 HSE Santorini Black
Tonight the stick hitting a fence noise reappeared. It sounds for all the workd like something hitting the propshaft or the cv in centre failed. I feel the vibration through the floor, underneath the car I can replicate the noise while moving the propshaft... video shows the noise. Propshaft does not feel 'right' at all. centre bearing appears ok, rear diff both shafts attempt to move when I move propshaft slightly (neutral selected on g'box) Is the clunk from propshaft/transfer box to much?
What symptoms does a failing transfer box manifest as?
I will be removing prop tomorrow after work ans take it from there. But any help as in direction to look would be greatly appreciated.
I also can't figure out how to upload a video 😂
Post #628502 Wed Nov 23 2022 10:34pm
https://www.rrsport.co.uk/gallery/albums/u...AA0CC7.MOV
Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #628506 Wed Nov 23 2022 11:21pm
Hodson91
Hi did you ever get to the bottom of this bud?
Regards 2010 RRS, TDV6
Santorini Black / Black Leather Interior
Black Side Steps, Black Autobiography Grill and Side Vents
22" Calibre Satin Black Alloys
ALSO IN THE FLEET
X2 2008 Focus 2.5 Turbo ST225 both approx 330bhp, Electric Orange
2011 Mondeo 2.2 Titanium X Sport Auto, Frozen White
2007 Fiesta ST150 2.0, Silver
2011 Swift Challenger 570SR Caravan
Post #639646 Tue Feb 13 2024 9:35pm
DaftRascal
Yes, I did. Applogies for not updating the thread It was the new Propshaft which was at fault. The splines
from shaft into the front UJ that bolts to the Transfer Box were the issue. All 4 wheel bearings and a
front diff later! Front diff did have quite a bit of play on the n/s bearings though so that was needing fixed anyway.
Post #639652 Wed Feb 14 2024 9:12am
Hodson91
I think i have the same noise. Like a rotational dunk dunk dunk
Was it the rear prop you replaced that cured it
Kind regards 2010 RRS, TDV6
ALSO IN THE FLEET
Post #639657 Wed Feb 14 2024 11:12am
DaftRascal
Yes, the rear section. I bought the faulty one from Amazon for £169 and it was on perhaps 4-5 weeks. Reason for changing it was the centre bearing/bushing was away. Genuine RR prop back on it now though.
Post #639674 Wed Feb 14 2024 10:13pm
DaftRascal
I could replicate the noise by turning at the propshaft by hand underneath the car. Not as loud or definitive but it gave clear indication.
Post #639675 Wed Feb 14 2024 10:15pm
Hodson91
Thanks for getting back to me i will have a look
The noise you described is the noise i think im getting, though i dont know if my ears are playing tricks on me but im adamant its coming from the front. Hence why ive replaced both front drive shafts and the front diff. They're definitely a labour of love these things haha 2010 RRS, TDV6
ALSO IN THE FLEET
Post #639706 Thu Feb 15 2024 10:18pm
DaftRascal
That sounds the exact same issue as I had. I was 100% convinced it was the front end somewhere. When under the car and twisting at the propshaft by hand I couldn't get it to make the exact noise or even really feel much play but I did get the hollow 'tingy' strange noise for like 1 click if that makes sense?
Post #639730 Sat Feb 17 2024 8:19am
Hodson91
Yes i didnt feel much play in mine to be honest and i cant get it to fault whilst i run it on the ramp as it needs to be under load.
But i will check this Monday morning, thank you. 2010 RRS, TDV6
ALSO IN THE FLEET
Post #639740 Sat Feb 17 2024 5:58pm
DaftRascal
Under load was when I noticed it most. At end up it was quite distinct. I'm sure that will be the issue with yours as well.
Post #639746 Sat Feb 17 2024 10:15pm
Hodson91
I notice the noise on mine the most in reverse to be honest. As im reversing into my parking space at home. Its safe to say that i was very annoyed when i heard it the day i replaced the front diff Rolling Eyes 2010 RRS, TDV6
ALSO IN THE FLEET
Post #639747 Sat Feb 17 2024 11:16pm
