![]() | Home > General > Alarm |
Crraigymmmmm Member Since: 06 May 2021 Location: Peterborough Posts: 163 ![]() ![]() ![]() |
2 beeps normally means there is a reason for it not to lock, but if they are all locked then im confused. is the fuel flap locking? |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 960 ![]() ![]() ![]() |
Have the exact same issue with mine,,, sometimes takes a couple of goes to lock it but I'm sure the fault is with the drivers door lock mechanism. Stand next to each door when trying to lock to see if they do attempt to lock. 2010 RRS, TDV8
karlos01 Member Since: 02 Jan 2022 Location: norfolk Posts: 309 ![]() ![]() ![]() |
do you get anything flash up on the dash
Silverstone Member Since: 04 Sep 2014 Location: Towcester Posts: 184 ![]() ![]() ![]() |
Mine does this - even did it tonight. Bizarrely, I get double beeps if I try keyless locking but the fob is not close enough to the car (e.g. in a coat I have placed on the ground, nearby). Move fob closer and car locks as normal. There is no replacement for displacement - W O Bentley
