![]() | Home > Technical > Rear Anti roll bar leakage. |
alfapat Member Since: 25 Sep 2021 Location: Elgin Posts: 215 ![]() ![]() ![]() |
Has anyone had success with Lucas Hydraulic leak stop for seals on anti roll bar . I have a small leak there , output bar, in for a penny , might save a pound? |
Nilrem280 Member Since: 02 Jun 2020 Location: Portchester Posts: 84 ![]() ![]() ![]() |
You might save £1.4k which was what I paid to have my rear bar replaced. |
Iomegas Member Since: 16 Nov 2020 Location: Newcastle Upon Tyne Posts: 217 ![]() ![]() ![]() |
Hi I’ve heard good reports about this BLUE DEVIL HYDRAULIC STOP LEAK |
So I have got Granville Stop leak , after assking questions on shopping line , its suppost to be compatible , will see if it helps. |
jases4x4 Member Since: 28 Dec 2014 Location: yorkshire Posts: 253 ![]() ![]() ![]() |
Please update us if this works, Anyone else tried this with success before? |
Interesting link on Blue Devil! |
Not discounting the Blue Devil , sent an email to Manufacturer and still waiting for a reply. So went with Granville meantime. Thanks |
Hi I think the ACE system takes 2.5 us quarts so would put in 3 fluid oz. |
3 Fluid ounces doesn't sound a lot . I was advised the the Granville stop leak required the whole can which is 0.375 ml oh well Ill report my findings as well. |
Hi i checked with a friend in America that used it and he checked an email he had from the company stating that for the ACE system that’s the quantity to use he said you do t use massive amounts of this stuff.He is a farmer over there and uses it on his tractors and other hydraulics and used it on his RR .
What is 3 fluid ounce? The bottle is 946ml so is that 300ml or more would you say gents? |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5120 ![]() ![]() ![]() |
Long time since I went to school, but I think 3 fl.oz is about 90ml (88.7206 to be exact). |
Cheers Col, Thats not alot then but i suppose the key is not to put too much in, This bottle is nearly a litre so theres alot of waste, Still if it does work its worth it. My other question is the filter in the valve block, is it worth replacing before or after using blue devil? |
