Home > Technical > Rear Anti roll bar leakage.
alfapat
United Kingdom 2007 Range Rover Sport TDV8 HSE Stornoway Grey
Has anyone had success with Lucas Hydraulic leak stop for seals on anti roll bar . I have a small leak there , output bar, in for a penny , might save a pound?
Post #627950 Fri Nov 04 2022 3:02pm
Nilrem280
United Kingdom 2010 Range Rover Sport TDV8 HSE Nara Bronze
You might save £1.4k which was what I paid to have my rear bar replaced.
Post #627956 Fri Nov 04 2022 4:40pm
Iomegas
United Kingdom 2013 Range Rover Sport 3.0 TDV6 HSE Santorini Black
Hi I’ve heard good reports about this BLUE DEVIL HYDRAULIC STOP LEAK Thumbs Up
Post #627960 Fri Nov 04 2022 6:59pm
alfapat
So I have got Granville Stop leak , after assking questions on shopping line , its suppost to be compatible , will see if it helps.
Post #628309 Thu Nov 17 2022 9:11pm
jases4x4
United Kingdom 2010 Range Rover Sport TDV8 Autobiography Santorini Black
Please update us if this works, Anyone else tried this with success before?
Post #628313 Thu Nov 17 2022 11:33pm
Iomegas
https://www.rrsport.co.uk/forum/topic56702...blue+devil
Post #628314 Fri Nov 18 2022 7:33am
alfapat
Interesting link on Blue Devil!
Post #628320 Fri Nov 18 2022 11:55am
alfapat
Not discounting the Blue Devil , sent an email to Manufacturer and still waiting for a reply. So went with Granville meantime. Thanks
Post #628321 Fri Nov 18 2022 11:57am
jases4x4
I have purchased 1ltr of blue devil as i was planning on replacing the rear ace bar next year so its worth trying, I just need to find out the amount of hydraulic fluid thats in the ace system on a 2010 3.6 v8 does anyone know the capacity? Then i can work how much of the blue devil to put in, Then i will keep the thread updated over the coming months to see if this stuff actually works on the Ace systems or not.
Post #628396 Mon Nov 21 2022 3:53pm
Iomegas
Hi I think the ACE system takes 2.5 us quarts so would put in 3 fluid oz. Thumbs Up
Post #628398 Mon Nov 21 2022 4:33pm
alfapat
3 Fluid ounces doesn't sound a lot . I was advised the the Granville stop leak required the whole can which is 0.375 ml oh well Ill report my findings as well.
Post #628403 Mon Nov 21 2022 6:32pm
Iomegas
Hi i checked with a friend in America that used it and he checked an email he had from the company stating that for the ACE system that’s the quantity to use he said you do t use massive amounts of this stuff.He is a farmer over there and uses it on his tractors and other hydraulics and used it on his RR .
He sent me this from the reply he got .
BlueDevil Hydraulic Stop Leak is safe and compatible to use in your Land Rover. You should apply 1 ounce of BlueDevil per every 1 quart of fluid capacity; more is not better. Thumbs Up
Post #628405 Mon Nov 21 2022 6:51pm
jases4x4
What is 3 fluid ounce? The bottle is 946ml so is that 300ml or more would you say gents?
Post #628420 Mon Nov 21 2022 9:38pm
Long time since I went to school, but I think 3 fl.oz is about 90ml (88.7206 to be exact). Laughing
Post #628425 Mon Nov 21 2022 10:01pm
jases4x4
Cheers Col, Thats not alot then but i suppose the key is not to put too much in, This bottle is nearly a litre so theres alot of waste, Still if it does work its worth it. My other question is the filter in the valve block, is it worth replacing before or after using blue devil?
Post #628430 Mon Nov 21 2022 10:28pm
