![]() | Home > General > Slight. Strange L320 starting issue |
karlos01 Member Since: 02 Jan 2022 Location: norfolk Posts: 309 ![]() ![]() ![]() |
check the battery terminals are tight they might just be a little loose |
Toonraider Member Since: 15 May 2022 Location: Newcastle upon Tyne Posts: 117 ![]() ![]() ![]() |
Proper tight. Its weird, like a split second cut off before it cranks again to fully start. |
could be loose wire on the starter or bad earth on it |
Will check that at weekend. Is it accessible? |
you got petrol or diesel one |
Diesel 2.7 |
NoExpert Member Since: 28 Jan 2022 Location: Poznań, Poland Posts: 511 ![]() ![]() ![]() |
How’s the battery check out?
Aye, good shout that. How can I test that or is it just change it regardless and hope that's the issue. |
That would be difficult to test. Could try testing resistance when cold and then when hot. However, if it’s only a second or so it stops you may not see much on the meter. Could try making a heat shield for it or getting a heat shield blanket for it. I’m definitely thinking heat soaked starter since my R1 would do the exact same thing. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Good tip, cheers. Its less than a second if I'm honest. |
