Home > General > Slight. Strange L320 starting issue
Toonraider
United Kingdom 2008 Range Rover Sport TDV6 HST Stornoway Grey
On my first journey of the day, car starts fine.
But pop in for fuel or to a shop say and then when I go to start it cranks for a split second, kind of drops out for a split second then continues the process until fired up.
Not all the time but it's regular enough to warrant this post.
Iany ideas?
Post #627242 Sun Oct 09 2022 8:13pm
karlos01
check the battery terminals are tight they might just be a little loose
Post #627243 Sun Oct 09 2022 9:47pm
Toonraider
Proper tight. Its weird, like a split second cut off before it cranks again to fully start.
Post #627247 Mon Oct 10 2022 12:15pm
karlos01
could be loose wire on the starter or bad earth on it
Post #627249 Mon Oct 10 2022 1:14pm
Toonraider
Will check that at weekend. Is it accessible?
Post #627282 Tue Oct 11 2022 6:22pm
karlos01
you got petrol or diesel one
Post #627288 Tue Oct 11 2022 8:39pm
Toonraider
Diesel 2.7
Post #627330 Wed Oct 12 2022 6:57pm
NoExpert
How’s the battery check out?
Could be the starter solenoid dying. First startup it’s cold so no problem. Second startup it’s heat soaked and starting to bind. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Post #627332 Wed Oct 12 2022 8:06pm
Toonraider
Aye, good shout that. How can I test that or is it just change it regardless and hope that's the issue.
Post #627352 Thu Oct 13 2022 4:53pm
NoExpert
That would be difficult to test. Could try testing resistance when cold and then when hot. However, if it’s only a second or so it stops you may not see much on the meter. Could try making a heat shield for it or getting a heat shield blanket for it. I’m definitely thinking heat soaked starter since my R1 would do the exact same thing. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Post #627355 Thu Oct 13 2022 6:32pm
Toonraider
Good tip, cheers. Its less than a second if I'm honest.
Post #627380 Fri Oct 14 2022 8:58pm
