| RRSPORT.CO.UK | ||
|  | Home > Technical > Alarm occasionally goes off without reason |
| Stevepd Member Since: 22 May 2017 Location: Wiltshire Posts: 1251      | Could be that the battery is getting low. 2006 2.7 TDV6 HSE in Cairns Blue. | ||
|  Thu Sep 22 2022 7:59pm |
| Nilrem280 Member Since: 02 Jun 2020 Location: Portchester Posts: 84      | Common problem, usually the bonnet switch. A quick fix is to join the 2 wires together. | ||
|  Thu Sep 22 2022 8:12pm |
| AIJ 615 Member Since: 19 Sep 2022 Location: Tamworth Posts: 122      |
 Oh my I think you have something here. I’ve only had the car just under a week however I keep getting error of low battery but I’ve taken it to Halfords and it’s 97% efficiency and also dealer said it was a fairly new battery. Maybe because it’s not been used much and say on forecourt ? I’m going Blackpool in morning so maybe that will give it a good run and charge ? Alan | ||
|  Thu Sep 22 2022 8:20pm |
| NoExpert Member Since: 28 Jan 2022 Location: Poznań, Poland Posts: 522      | Or the BMS wasn’t reset when it was installed. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
|  Thu Sep 22 2022 8:29pm |
| AIJ 615 Member Since: 19 Sep 2022 Location: Tamworth Posts: 122      | BMS ? | ||
|  Thu Sep 22 2022 8:42pm |
| AIJ 615 Member Since: 19 Sep 2022 Location: Tamworth Posts: 122      | Further reading and it could possibly be the auxiliary battery ?
|  Thu Sep 22 2022 9:01pm |
| Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5156      | You don't have a Aux battery on a RRS1 L320. BMS battery monitoring system, basicaly it keeps a eye on the battery charge state, if the charge level drops it start to shutdown various circuits so you have enough charge to start the vehicle in theory. Don't get to excited about it as they periodically self calibrate anyway, mine has thrown up low battery occasionally since day one nearly 10 years and never failed to start, one thing I would suggest assuming it is practical to connect it depending where you park is buy a Ctek charger, especially if you do not use the vehicle for several day's at a time.
|  Thu Sep 22 2022 9:08pm |
| AIJ 615 Member Since: 19 Sep 2022 Location: Tamworth Posts: 122      | Ok cheers Col
|  Thu Sep 22 2022 9:18pm |
| Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5156      | Bent paper clip and bridge out the connector temporarily to check if that is the issue, if you do a search on the forum there have been a few post's about it.
|  Thu Sep 22 2022 9:23pm |
| AIJ 615 Member Since: 19 Sep 2022 Location: Tamworth Posts: 122      | 👍 | ||
|  Fri Sep 23 2022 12:55am |
| Stevepd Member Since: 22 May 2017 Location: Wiltshire Posts: 1251      | https://www.rrsport.co.uk/forum/topic56598.html
|  Fri Sep 23 2022 5:41am |
| AIJ 615 Member Since: 19 Sep 2022 Location: Tamworth Posts: 122      | Appreciate the support guys
|  Fri Sep 23 2022 8:06am |
| NoExpert Member Since: 28 Jan 2022 Location: Poznań, Poland Posts: 522      | Do you have the interior sonic sensors for the alarm? Mine seem to be aggressively sensitive and pick up the dash expanding. In the summer I’ll run the A/C so the interior is nice and cold, park in the sun and 10-15 minutes later the alarm will go off without anything happening other than the car heating up in the sun. Same on colder mornings when my park heater kicks on and the dash starts getting warm. Mine has done this maybe ten times over the last year and typically occurs with the inside hot or cold and the outside temps are the opposite. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
|  Fri Sep 23 2022 9:06am |
| Dave B Member Since: 10 Oct 2019 Location: East/West Sussex Coast Borders Posts: 432      | My Disco had a lazy seat belt, and when it finally decided to fully retract, it was enough to set the alarm off.
|  Fri Sep 23 2022 2:59pm |
| Posting Rules
