Home > Maintenance & Modifications > Coolant type
BigBerthaTheRRS
United Kingdom 2005 Range Rover Sport TDV6 HSE Zambezi Silver
Coolant type
Hi all,
Need to top up coolant before a long journey to France. Currently the coolant in the tank is orangey/red colour. Manual says use Castrol SF. But on the spec sheet for Castrol SF it specifies colour as pink/violet. To confuse things more the safety sheet for Castrol SF says red.
I have the 2.7, any advice on coolant to use or a pre-mix alternative that I can use to top up? I want to avoid causing issues (although this seems unlikely)
Thanks 2005 2.7 tdv6 RRS Vin 6A
Post #626235 Tue Aug 23 2022 9:53am
Castrol SF is Pink/Violet, Castrol SF-O is Red
Post #626236 Tue Aug 23 2022 10:27am
BigBerthaTheRRS
Can I use both SF or SF-O? Manual says SF but this isn't the colour I have in... 2005 2.7 tdv6 RRS Vin 6A
Post #626238 Tue Aug 23 2022 10:52am
Certainly confusing just saw a Castrol spec. sheet that say's SF-O is Blue/Green in colour. Part of the problem is there is no standard for the colour it is just a dye and different manufactures use different colours down here the correct recommended spec. is blue. Depending on how much you need might be worth biting the bullet and get some from a dealer.
Post #626240 Tue Aug 23 2022 11:13am
BigBerthaTheRRS
Just had a chat with my local LR specialist/indie - for anyone in the same position, they recommended using Prestone coolant/antifreeze which he assured me is compatible with pretty much every other coolant you might find in your disco or RR sport so works well if you just need a top up. Its meant to be very good stuff though with the premium version lasting 15+ years. He said he is switching to use this stuff in all the ones he gets now because its great quality and doesn't coagulate with anything.
Cheers 2005 2.7 tdv6 RRS Vin 6A
Post #626243 Tue Aug 23 2022 12:05pm
I have used Halfords pre-mixed OAT Anti-freeze and coolant in both of my RRS for years:
https://www.halfords.com/motoring/engine-o...33536.html 2012 SDV6 - it's missing a couple of cylinders
Post #626246 Tue Aug 23 2022 4:06pm
gogsy1956
+1 for halfords pre mixed,, so easy to get hold of. 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #626249 Tue Aug 23 2022 8:27pm
