![]() | Home > Maintenance & Modifications > Coolant type |
BigBerthaTheRRS Member Since: 15 Dec 2021 Location: Market Drayton Posts: 23 ![]() ![]() ![]() |
Hi all,
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5067 ![]() ![]() ![]() |
Castrol SF is Pink/Violet, Castrol SF-O is Red
Can I use both SF or SF-O? Manual says SF but this isn't the colour I have in... 2005 2.7 tdv6 RRS Vin 6A |
Certainly confusing just saw a Castrol spec. sheet that say's SF-O is Blue/Green in colour. Part of the problem is there is no standard for the colour it is just a dye and different manufactures use different colours down here the correct recommended spec. is blue. Depending on how much you need might be worth biting the bullet and get some from a dealer.
Just had a chat with my local LR specialist/indie - for anyone in the same position, they recommended using Prestone coolant/antifreeze which he assured me is compatible with pretty much every other coolant you might find in your disco or RR sport so works well if you just need a top up. Its meant to be very good stuff though with the premium version lasting 15+ years. He said he is switching to use this stuff in all the ones he gets now because its great quality and doesn't coagulate with anything.
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9060 ![]() ![]() ![]() |
I have used Halfords pre-mixed OAT Anti-freeze and coolant in both of my RRS for years:
