![]() | Home > General > Oil Filler Cap |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5117 ![]() ![]() ![]() |
jaguar 2.7 (S type, XJ6 x350, XF 2.7)
You don't need to torque them up. Just tighten them till they stop turning
Oh and the oil filters are different between 2.7 and 3.0
oh and it really helps if you fill in your profile, then I'm not assuming you have a 2.7 and giving you the wrong parts and info |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5132 ![]() ![]() ![]() |
Based on a previous post in the L494 section I think the OP has a 2016 L494 3.0L, and why would you not bother to torque the cap up when it does actually have a figure of 25Nm moulded in to the cap for this purpose, presumably amongst other things to stop it being over tightened and possibly cracking being some sort of plastic composite material.
NoExpert Member Since: 28 Jan 2022 Location: Poznań, Poland Posts: 493 ![]() ![]() ![]() |
Citroen part number 1103 T4. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Craig_John Member Since: 27 Mar 2022 Location: Cumbria Posts: 35 ![]() ![]() |
All,
