![]() | Home > General > Air suspension compressor required |
Salisburylander Member Since: 16 Mar 2014 Location: Salisbury Posts: 247 ![]() ![]() |
A bit of research shows that the new LR compressor is the one to go for. |
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1070 ![]() ![]() |
The Hitachi is the genuine Land Rover item - is easy to rebuild rather than getting a new one.
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5102 ![]() ![]() ![]() |
If the Vin No. is prior to BA708255 it could well be a Hitachi, as according to L/R they did not start fitting the AMK till after that vin. number. On some MY12/13 cars they reverted back to the Hitachi and then back to the AMK again, just to confuse things. Drop the plastic cover and have a look, easy enough to tell the difference.
Sounds a bit like they just had a rummage in the parts bin at the factory to see what compressors they could find, Col! |
Update: I’ve had the new AMK compressor fitted (software update included) and also had the air tank replaced. The tank was particularly corroded by the pipe fittings.
