Home > General > Air suspension compressor required
Salisburylander
2011 Range Rover Sport 3.0 TDV6 HSE Bali Blue
I recently had my wheel bearings replaced and whilst I was in the garage, a suspension fault warning came up on the dashboard. The garage plugged their computer in and it came up with a low air fault ie the compressor had seen better days. It’s still the original one.
Do I replace it with Hitachi or go with a Genuine Land Rover one?
Post #625638 Sat Jul 23 2022 10:37am
Salisburylander
A bit of research shows that the new LR compressor is the one to go for.
Post #626195 Sat Aug 20 2022 11:45am
garrycol
Australia
The Hitachi is the genuine Land Rover item - is easy to rebuild rather than getting a new one.
Hang on - looked at your vehicle - a 2011 so it will have the AMK from new not a Hitachi - so see if yours can be rebuilt, if not buy a genuine AMK not a knock off. 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #626196 Sat Aug 20 2022 12:01pm
If the Vin No. is prior to BA708255 it could well be a Hitachi, as according to L/R they did not start fitting the AMK till after that vin. number. On some MY12/13 cars they reverted back to the Hitachi and then back to the AMK again, just to confuse things. Drop the plastic cover and have a look, easy enough to tell the difference.
Post #626197 Sat Aug 20 2022 12:23pm
aaronjb
Sounds a bit like they just had a rummage in the parts bin at the factory to see what compressors they could find, Col! Laughing 2014 BMW 530d Touring, 2006 BMW 650i, 2018 Mini Cooper S
Post #626226 Mon Aug 22 2022 11:37am
Salisburylander
Update: I’ve had the new AMK compressor fitted (software update included) and also had the air tank replaced. The tank was particularly corroded by the pipe fittings.
Car feels exactly the same as it did prior to the work although going into “Off road” mode seems especially quick.
Post #627366 Fri Oct 14 2022 9:50am
