![]() | Home > General > P0234-77 Turbo Overboost - SDV6 L494 |
SAK335 Member Since: 02 Apr 2022 Location: Henley-on-Thames Posts: 22 ![]() ![]() |
No coding is necessary. It's a pretty straightforward replacement. |
Fozza RR Member Since: 06 May 2023 Location: West Midlands Posts: 3 ![]() ![]() ![]() |
Thanks for the reply, I have had it off to clean and it was really gunked up
The dealers are clueless. The throttle causes the error code and the error code suspends DPF regeneration. The DPF will clog again. Go to YouTube and look up a guy called OReillys Mobile Mechanics. He's put out some good videos on this issue on JLR vehicles and shows how to clean the DPF without removing it. |
PhilMid Member Since: 14 Aug 2015 Location: Hull, East Yorkshire Posts: 61 ![]() ![]() ![]() |
They did a software update when I had my throttle body replaced. Don’t completely know why it had to be done, but it’s been fine since the throttle body change.
Sitchey Member Since: 11 Jul 2021 Location: Armagh Posts: 10 ![]() ![]() |
Hi. Did you ever get yours sorted fully? I've 2015 RRS and going around in circles. P24A4-97 Diesel particle filter restriction- soot accumulation too high - bank 1 State: Intermittent P0234-77 Turbo/supercharger overboost condition State: Intermittent I have had my DPF flushed and a brand new throttle body installed. Keep getting the same issues over and over. My turbo pressure is fine and no whines and evident smoke. But something still isn't right. |
SAILORSAM Member Since: 11 Nov 2023 Location: HAYLING Posts: 7 ![]() ![]() |
Getting the same but the turbo over pressure only seems to be triggered by the car trying to do a regen. In normal use no fault comes up but when I go to force a region via tool, it triggers the fault and won't regain. Have cleaned the DPF and new LR Throttle body |
Getting the same but the turbo over pressure only seems to be triggered by the car trying to do a regen. In normal use no fault comes up but when I go to force a regen via tool, it triggers the fault and won't regen. Have cleaned the DPF and new LR Throttle body
2 things to consider that might help
Any idea how to do the software reset? I have a Gapp-IID tool but doesn't seem to have anything to do it |
Sorry my mechanic did it in a few secs. Tool I had didn't have the option |
So i changed the Throttle body and the Oil breather and took it for a run. When i use the gap iid to try and force regen the Dpf it immediately fails with code P0234-77 happening. Cleared the fault and then drove for a while to find the car then did its own regen and didnt trigger the code! |
Hope that's it sorted for you. Mine has been fine since those 2 steps.
Eventually got this solved. Throttle body change alone didnt stop the code being thrown up. Garage had to an air path update in the software and since then all working |
Good to see u got it sorted. An absolute nightmare these codes as never the part people expect it to be. |
