![]() | Home > Technical > L320 Passenger footwell light |
AndyCHO Member Since: 23 Dec 2021 Location: Wodonga Posts: 125 ![]() ![]() ![]() |
I have been changing out the interior lights in our RRS 2010 with LED's and the last one to do was the Passenger footwell lamp especially as it wasnt working anyway.
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5134 ![]() ![]() ![]() |
If I remember right, two small turnbuckle screws just below bottom edge of lower glove box lid, grab the small piece of carpet trim attached to the panel by the transmission tunnel and give it a gentle tug there is a hidden spring clip behind it, should then be able to lower panel enough and wiggle it out, if you still can't get it right out you may have to remove the piece of footwell trim by the bonnet release lever should then drop straight out.
Perfect description on how to do it... it took me a little while to figure out the carpeted bit at the Trans tunnel but once I gave that a gentle tug it camee off rather easy... went back on easy too.
