![]() | Home > Maintenance & Modifications > SVR brake part numbers |
karlos01 Member Since: 02 Jan 2022 Location: norfolk Posts: 309 ![]() ![]() ![]() |
don't have topic I've got a site called lrcat but only goes up to 2014 models I get my part numbers off there |
Dave B Member Since: 10 Oct 2019 Location: East/West Sussex Coast Borders Posts: 432 ![]() ![]() ![]() |
If you go on the autodoc uk website (also the best place to buy Brembo discs), search by your registration, and then by vehicle type, you can find out what was fitted to any vehicle and then compare.
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4521 ![]() ![]() ![]() |
Front discs changed at JA chassis, but are still 380mm..
Farmer Chalk Member Since: 02 May 2015 Location: London Posts: 554 ![]() |
Thanks Dave, Used Autodoc to purchase the Brembo discs and pads … far cheaper than Euro Car Parts even with their 50% discount on Brembo ‘special’ !! Advanced Factors we’re cheaper still but can’t get Brembo… alas… for the other family cars I would use them.. Thanks all again for your help! Ian |
Just like to thank Dave and Mikey for their assistance… Autodoc were excellent… full set of genuine Brembo front and rear discs and both sets of pads for £411.00!
Don't use copper slip on aluminium calipers. A non-metallic grease should be used, such as ceramic grease |
Every day is a school day…what does it do then?
The copper reacts with the aluminium, causing galvanic (?) corrosion, and eats away at the aluminium
Yeouch! Thanks for highlighting this… looks as though I’ll be back under the car again to clear it off those bolts… many many thanks for highlighting this… I thought it was inert.. |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9130 ![]() ![]() ![]() |
You said that you used ceramic grease and D_M said to use ceramic grease so you appear to have gone the right way already. 2012 SDV6 - it's missing a couple of cylinders
Hmmm not totally… I used the ceramic grease on the pad upper and lower surfaces and on the pins…
Bet your the geeky/nerdy one now |
I’m well smart am I! |
