Home > Maintenance & Modifications > L494 colour coding door trim and bumper corners
GroosterUK
Hi, I’m new here, so be gentle. I’ve just bought my first RRS from a main dealer at the weekend, having had Merc’s for the past 10 years. Loving it so far and I’ve added a few bits already.
It’s Yulong white. I’ve had the silver 21” alloys changed to gloss black. I’ve added the black pack, (front rear tow panels, rear door black strip, front fogs and front grill).
All looks good in my eyes apart from the lower door trim and bumper corners being in matt black. The factory option wasn’t ticked at birth.
I’ve asked a couple of body shops that I know about colouring them white. One of them said it was a big job with having to sand them down, prime and colour, £800.
The other and a friend of the family wouldn’t touch them, saying that they would always be susceptible to chipping and peeling if they were sprayed over. Didn’t want to put his name to it.
Basically has anybody had this done.
Can you buy the parts from JLR colour coded already or smooth and ready to spray.
Or should I just keep it as it is.
I’ve added a couple of photos. My car before I added the black pack tonight and a car similar to what I’m wanting.
Thanks
Post #621538 Thu Feb 03 2022 8:37pm
You used to be able able to buy the trims for L/R either finished in the unpainted black, or finished in primer ready for spraying to body colour, you cannot buy them ready colour coded from L/R. If the original ones are prepared and primed with correct primer by the bodyshop I see no reason why there should be any problem with colour coding the originals. Personally I hate white cars with black wheels, however saying that the white does looks so much better with the trims colour coded.
Post #621542 Thu Feb 03 2022 9:08pm
GroosterUK
Cheers Col. the painting side of things, I had the same thought. If they prep the trims correctly, it shouldn’t peel off or chip. I’m just thinking he couldn’t be bothered with the job. But £800 with the other company seems excessive, I’m out of touch with prices though.
I might get a third opinion tomorrow and take it to another body shop.
Post #621543 Thu Feb 03 2022 10:12pm
How about these from a forum member, could have them colour coded white and fit yourself might save a few pounds, easy enough to fit, just need a few new clips.
https://www.rrsport.co.uk/forum/topic59320.html
Post #621544 Thu Feb 03 2022 10:25pm
GroosterUK
I presume these are just the same as mine. They would need sanding and priming first. If they were primed I would definitely be interested.
I get that it might be easier just taking them to a body shop but I’d still need the 4 corner bumper pieces as well.
I’ve actually seen a full set of door trims on eBay, OEM but primed at £150.
Post #621546 Thu Feb 03 2022 10:42pm
Red Arrow
I also have another set that are primed Thumbs Up
Drop me a PM
Post #621551 Fri Feb 04 2022 1:09am
GroosterUK
pm sent
Post #621565 Fri Feb 04 2022 12:38pm
Mblondon
United Kingdom 2013 Range Rover Sport 3.0 TDV6 HSE Orkney Grey
Hi mate
Just come across this post, I’m in a very similar situation as you sound like are/was. I’m about to get into a new RRS which I didn’t spec and thus I need to make a few cosmetic changes. Primarily I need to colour code the lower black trim and possibly add a black pack. Can I ask how you got on colour coding your trim and regarding the black pack which you added, did you go aftermarket or oem?
Best
MBL
Post #622030 Fri Feb 18 2022 7:19pm
GroosterUK
I managed to source genuine parts for everything I needed on eBay.
Luckily somebody was selling a used but mint condition Black pack from a car they were selling. Really easy to fit.
As for the colour coding, I again sourced genuine parts on eBay. This time brand new and already primed and they are at the body shop as I type. They’re being painted and the car will go in next week for them to be fitted.
Saved a fortune..
Post #622033 Fri Feb 18 2022 7:55pm
Turdmon
Where in Preston are you mate? South Ribble here. Smile
Post #622050 Sat Feb 19 2022 11:23am
GroosterUK
I’m up in the sunny north, near Longridge Thumbs Up
Post #622051 Sat Feb 19 2022 11:29am
Turdmon
We've just been through there, funnily enough. Looks like you had a bit of snow today?!
Post #622060 Sat Feb 19 2022 7:04pm
Red Arrow
Mblondon wrote:
Hi mate
Best
MBL
I have the rear door mouldings that have been smoothed and primed ready for paint , they have the rubbers etc Thumbs Up
Post #622086 Sun Feb 20 2022 4:54pm
Mblondon
Helpful and appreciated but presumably I need the whole kit?
Post #622093 Sun Feb 20 2022 7:23pm
