Home > Maintenance & Modifications > L494 colour coding door trim and bumper corners |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4891 |
You used to be able able to buy the trims for L/R either finished in the unpainted black, or finished in primer ready for spraying to body colour, you cannot buy them ready colour coded from L/R. If the original ones are prepared and primed with correct primer by the bodyshop I see no reason why there should be any problem with colour coding the originals. Personally I hate white cars with black wheels, however saying that the white does looks so much better with the trims colour coded.
Thu Feb 03 2022 9:08pm |
GroosterUK Member Since: 02 Feb 2022 Location: Preston Posts: 17 |
Cheers Col. the painting side of things, I had the same thought. If they prep the trims correctly, it shouldn’t peel off or chip. I’m just thinking he couldn’t be bothered with the job. But £800 with the other company seems excessive, I’m out of touch with prices though.
Thu Feb 03 2022 10:12pm |
How about these from a forum member, could have them colour coded white and fit yourself might save a few pounds, easy enough to fit, just need a few new clips.
Thu Feb 03 2022 10:25pm |
I presume these are just the same as mine. They would need sanding and priming first. If they were primed I would definitely be interested.
Thu Feb 03 2022 10:42pm |
Red Arrow Member Since: 06 Jun 2017 Location: Scotland Posts: 578 |
I also have another set that are primed
Fri Feb 04 2022 1:09am |
pm sent |
Fri Feb 04 2022 12:38pm |
Mblondon Member Since: 18 Feb 2022 Location: London Posts: 17 |
Hi mate
Fri Feb 18 2022 7:19pm |
I managed to source genuine parts for everything I needed on eBay.
Fri Feb 18 2022 7:55pm |
Turdmon Member Since: 05 Aug 2020 Location: Lancashire Posts: 97 |
Where in Preston are you mate? South Ribble here. |
Sat Feb 19 2022 11:23am |
I’m up in the sunny north, near Longridge |
Sat Feb 19 2022 11:29am |
We've just been through there, funnily enough. Looks like you had a bit of snow today?! |
Sat Feb 19 2022 7:04pm |
I have the rear door mouldings that have been smoothed and primed ready for paint , they have the rubbers etc |
Sun Feb 20 2022 4:54pm |
Helpful and appreciated but presumably I need the whole kit? |
Sun Feb 20 2022 7:23pm |
